il 02/03/2007, 20:18
da discoweb.org
Discovery Series II
255/65-16: Stock tire size.
255/70-16: Just a bit taller than stock.
265/75-16: Taller and wider than stock, possible to fit without lift. minor rubbing. Looks real balanced with mild OME lift.
285/75-16: even taller than 265/75-16, r requires a bit more lift than the regular OME lift. some have fitted OME751 from Discovery series I, and changed SLS sensor in the rear to achieve almost 3 inches. Gearing and shaft strenght become issues.
255/85-16: a bit taller than 285/75-15 but narrower. Gearing and shaft strenght become issues.
Reno
Vivi come se dovessi morire subito, pensa come se non dovessi morire mai.
Reno
