Servicing, repairing or even just inspecting your 4x4 often requires crawling around in the cramped space between axles, transmissions, bodywork and driveway or garage floor.
It’s amazing how much easier this task can be made if the vehicle is raised a few extra inches above the ground before work commences.
The ideal way to do this is with purpose-designed vehicle ramps. But those available in car accessory shops are usually woefully lacking - being both too narrow for bigger 4x4 tyres and not stable enough for the higher 4x4 centre of gravity.
These Extra Wide, High Stability, Heavy Duty Vehicle Ramps are the perfect solution, and are ideally suited to bigger 4x4’s fitted with large or wide tyres.
Unlike inferior ramps, the profiled edges of the support “rungs” allow vehicles to climb up the ramps in a slow and controlled fashion without pushing the ramp forwards away from the tyre.
For extra security and safety, the swept angle of the supporting side rails draw the vehicle’s tyre towards the safety end stop and helps prevent inadvertent rolling back off the ramps.
Made in the UK these ramps are tested to 1,500Kg each or 3,000Kg per pair when evenly loaded.
Length 920mm
Width at Base = 340mm
Width at Tyre Rungs = 240mm
Raising Height = 240mm
Luca
Disco 300 tdi
Nord-Ovest Club Member
